With iClone you have the option for 16K render (high end video card recommended) or limit your max texture relsolution to something like 4K The full scene loaded and iClone set to render 16K will cost 6.3 GB of Video ram -But! you also have the option of detaching and deleting any of the 5 models if you wish. -16K Max resolution of terrain models x4 (Modular) - Flip and rotate to build scenes -All 4 Terrain models share the same material/textures! -4K River-comes with a sound loop that works fine in a Video Editor but you may want to copy, paste and squish them together. -Requires the Smooth Mesh by subdivision beset to Level1, tesselation quality is optional. -River material/textures can be used on other models (not baked) **Vegitation & IBL image not included** To paint vegetation on the models first convert the model or models to terrain go to top toolbar, modify, convert to terrain. With the terrain selected uncheckmark "use bounding mesh" which you may then move objects or vegetation over the mesh itself. Lastly you may consider using the terrain snap options under the Edit tab on the top toolbar. The models were not converted to terrain so that the textures would be exposed and allow you to modify them as you wish.
Universal Project
PBR
