Introducing WarLord's Weapons of War series. This series contains modern warfare weapons from the late 20th and early 21st centurys. I N C L U D E S : 1 - Animated 9MM Pistol 1 - Static 9MM Pistol NOTE: The animated version is attached to the static version for delivery. Select the animated pistol from the static pistol parts, detach and save for use. Use the static pistol to animate you own action using keyframes.
Universal
