For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (36)
G3 Skintight ANIMAL KINGDOM.iAvatar DOGs Packs Each Dog includes a DOG AML with 32 different canine Motions and 4 MOVE commands that work in director Mode. Skintight ANIMAL meshes use a small polygon footprint and are "Rigged" with exceptional quality. They are presented as Non-Human iClone Characters, i.e. iAvatars and therefore can be fully animated from within iClone using the iClone motion editor. The Dog is rigged with additional bones so that you can easily animate ears, tail and mouth. Each canine Cloth allows for texturing body, eyes, eyes sides, nose, teeth, tongue, tongue muscle and toes. About Animation Stationary motions are perfect “single” motion cycles. They are accessible using the Right Click "Perform" command. They carry the "St" sub-attribute to differentiate them from non-stationary motions. In order to see the full cycle, you need to select the motion and extend it on the timeline using the “Loop/Speed” Switch button. Non-Stationary motions are typically between 120 and 1500 frames long for your convenience. These can be cut at any desired length to fit your scene. Notes: The Motion files need to reside in the Reallusion "$iClone Template/Motion/" folder for the AML to find its way to the motion files.
Standard Human
