For iClone only:
Actor > Legacy Standard Human (1)
Animal Cat Leopard_1Ab
Animation > iMotion (22)
Cat_Idle_01
Cat_Idle_02
Cat_Idle_03
Cat_Stand_by
Cat_Walk_F_01_E
Cat_Walk_F_01_L
Cat_Walk_F_01_S
Cat_WalkIdle
CatGivePaw
CatRun
CatRunSt
CatSit2Stand
CatStand2Sit
CatStretch
CatStrut
CatStrutSt
CatWalk
CatWalkSlow
CatWalkSlowSt
CatWalkSlowToFast
CatWalkSlowToFastSt
CatWalkSt
G3 Skintight CATs
Skintight Cats includes AML with 15 different quadruped Motions and 4 MOVE commands that work in director Mode. These include several "Idle" and "Performance" moves as well as "MOVE" motions so that they can be animated while in Director Mode inside iClone. Motions are provided in both "Absolute Transform" mode an in Stationary "Loop" mode for your convenience. The Package also includes a wide variety of pre-textured Animals.
Skintight ANIMAL meshes use a small polygon footprint and are "Rigged" with exceptional quality. They are presented as non human iClone Characters, i.e. iAvatars and therefore can be fully animated from within iClone using the iClone motion editor.
The Cloth Skin, Eyes, Whiskers and Nose can be fully textured from the "Skin" TAB left hand-side Modify panel.
About Animation
Stationary motions are perfect “single” motion cycles. They are accessible using the Right Click "Perform" command. They carry the "St" sub-attribute to differentiate them from non-stationary motions. In order to see the full cycle, you need to select the motion and extend it on the timeline using the “Loop/Speed” Switch button. Non-Stationary motions are typically between 120 and 1500 frames long for your convenience. These can be cut at any desired length to fit your scene.
Notes: The Motion files need to reside in the Reallusion "$iClone Template/Motion/" folder for the AML to find its way to the motion files.
