For iClone only:
  • Set > Props (12)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animated Gear Assembly Props for iClone called ''EZ Gears''.
This is the EZ Animated Gears Vol.1 Pack by Bigboss.
This pack includes 12 fully animated Gear Assemblies including Belts, Pistons and Pulleys. The Gears are low polygon count and are fully optimized for real-time response
Best use in Steam Punk style Movies or any Movies requiring Robotics or Mechanical Assemblies.
Method of Use:
1) Apply EZ Gear Props to your scene
2) Build desired Robotics assemblies
3) Attach you rotating props to the desired Gear
4) Adjust Rotating Speed by stretching or compressing the animation Clip on the Timeline
5) Press Play
6) Multi-Duplicate as desired
7) Optionally attach all components to dummy Prop
8) Save Assembly for future use by saving dummy prop.
Further customize by modifying the accessible Materials for Gear, Piston, Rod, Belt and Shaft.
This Pack is complementary to all other EZ Gear Packs by Bigbos.
Have Fun ! :)
Bigboss40@videotron.ca
Universal
