Actor > Non-Standard Human (1)
Material > Material (12)
Set > Props (3)
Animation > rlMotion (20)
[/b]
This is the[b] Anubis Pack by SFBStudio.
This Pack contains 1 Anubis Creatures for iClone with 2 accessories plus 20 Animations and a set of 12 Materials to further customize your characters. The Creatures are supplied both as Non-Standard Humans and as Morphable Props with embedded Animations.
About SFBStudio Creatures:
Each Creature uses high quality PBR texture maps and a very small polygon count providing excellent visual quality for close-up shots.
Method of use:
1) Simply Apply the Prop or Non-Standard Human to your scene
2) Right Click on the Creature to select the appropriate performance
4) Use the Morph Animator to further customize your creature
5) Edit the applied animations on the timeline to add randomness to each character move
6) Use the supplied animations on other standard human characters
7) Further customize your characters using the materials supplied with the pack
8) Another interesting trick is to attach all your Creatures to a dummy Prop and have the prop follow an iPath during the animation
Have fun!
iClone > Actor > Humanoid > Fantasy Humanoid
iClone > Set > Props > Creature Prop
