Character > Accessory (46)
Material > Lower Body (15)
46 Arm Bands ready to drop on your character.
Morph Sliders
All arm bands, except a couple thin ones, have morph sliders that help with fitting inside of iClone. Scale in or out the top or bottom of the band or squash the sides of the bottom or top independantly with morph sliders instead of dealing with the hassel of moving buckles, prongs, and leather ties.
15 Material ID Maps
If you want to use your own materials on the armbands, use the Material ID Maps in your substance painter program to to make painting a breeze for you. For exsample, If you use Marmoset Toolbag as your substance painter, the color map will allow you to just drop a material onto that color and your substance painter will automaticly fill that whole color with that material. UV maps on bands are squared out makeing customizations or adding designs as easy as possible while at the same time help your materials look good and go in the direction you want them to go in. Now you can rock out with your ARM out!
