Actor > Non-Standard Human (2)
This is the Astronaut Pilot by Max Bugor
This Pack contains 2 Astronaut Pilot Character (same character in 2 color schemes). The Characters are supplied as a Non-Standard Avatar compatible with iClone Standard Motions.
About Max Bugor Characters:
Each Character uses high quality PBR shader maps and a very small polygon count providing excellent visual quality for close-up shots.
IMPORTANT TECHNICAL NOTES:
- You may hide some clothing layer (such as helmet) by selecting the appropriate material and moving the opacity slider to zero to reveil different faces or the underlying character.
Method of use:
1) Simply Apply the Character to your scene
2) Drag&Drop motion files provided with the pack on the Character or any other iClone standard human motions
iClone > Actor > Humanoid > Sci-Fi Humanoid
