  • Set > Props (71)
AWESOME LETTERS is a prop pack made of animatable letters and numbers designed in Cinema 4D. They are meant to be used in iClone 8 as drag-and-drop text and number props. The user can easily change the material property for each to their taste without hassle. And arranging them to build your own graphic text is often very easy because each letter is wrapped in an animatable letter box which you can use as a guide in arranging the whole text. AWESOME LETTERS are easy to use and very valuable in creating simple and complex texts in your iClone project.
It is useful for you to know that each letter is made up of the main text and its box.  The purpose of the letter box is to guide you as you combine the letters to form your desired words. This is because each letter box is the approximate size of the letter it houses. It is also serving as the main frame of the letter when the time scrubber is at zero level. However,  as you move the time scrubber forward,  the box collapses and the text reveals itself. The main purpose of the box is to help you in arranging the text. Also note that the text is a child of the box,  meaning you cannot delete the box without deleting the text. To make the box invisible,  use the make dummy button here. Also worthy of note is the vertex animation track. Both the letter and the letter box have the animation file in the vertex animation track,  not the usual animation track. Take note of this.You can move the file to your desired spot in the timeline for the text.
AWESOME LETTERS are here to boost your motion graphic projects in iClone 8. Gone are the days of struggling with static texts. You can now wow your clients with these high quality and  easy to use text and number props.
Universal
Human ShaderPBR
