  • Character > Cloth (6)
  • Character > Shoes (2)
Conforming Fantasy Outfit for CC3 Characters. Take your renders far into the uncivilized barbarian world. Original designed by Xurge3D and optimized by Reallusion for iClone and Character Creator.
Pack includes both high and low polycount models.  Use the low-poly models for normal or long distance shots and use the high-poly models for close up.
This new outfit comes in a set of 8 conforming parts. Each has been textured carefully to match the style of the outfit. Each part features completely flat mapping with no stretching, providing a great base for you to explore your own texturing ideas. All texture maps are optimized for PBR.  The high-poly models come with 3K texture maps and the low-poly models come with 2K.
When activating soft cloth physics in iClone, the shreds of clothing will react to the gravity and character’s movement, increasing dramatically the realism of movements.
This outfit is comprised of:
  ● Shirts
     - BarbLeath_M_Pouldrons ( High 44k polygon, Low 10k polygon )
      High Mesh installation path: \Cloth\Shirts\Xurge3D\Barbarian Leathers M\High Resolution
      Low Mesh installation path: \Cloth\Shirts\Xurge3D\Barbarian Leathers M
  ● Pants
     - BarbLeath_M_Pants ( High 33k polygon, Low 8k polygon )
      High Mesh installation path: \Cloth\Pants\Xurge3D\Barbarian Leathers M\High Resolution
      Low Mesh installation path: \Cloth\Pants\Xurge3D\Barbarian Leathers M
  ● Shoes
     - BarbLeath_M_Boots ( High 17k polygon, Low 5k polygon )
      High Mesh installation path: \Cloth\Shoes\Xurge3D\Barbarian Leathers M\High Resolution
      Low Mesh installation path: \Cloth\Shoes\Xurge3D\Barbarian Leathers M
  ● Others
     - BarbLeath_M_Bracers ( High 15k polygon, Low 3k polygon )
      High Mesh installation path: \Cloth\Others\Xurge3D\Barbarian Leathers M\High Resolution
      Low Mesh installation path: \Cloth\Others\Xurge3D\Barbarian Leathers M
Check out the full Xurge3D - Game Character Outfits pack.
CC3 CharacterCC3 CharacterCC Component
PBRExtended
