CC Basic 3 Bases provides 3 new bases: Cleavage Bustier, Cleavage Corset and Knee Length Skirt. Each bases is provided as a CC 1.5 Leather base and a CC 2.0 PBR Latex base. Although the bases are provided with a material (leather or latex depending on which version is used) so that they could be used as is, they are intended as bases from which other outfits can be created (by applying different materials and/or opacity maps).
Note: The main difference between the tops found in CC Basics Bases and the tops found in CC Basics 3 Bases is the fact that CC Basics Bases were completely body fitting meaning that the fabric followed the breasts even between the breasts which prevented the creation of outfits that showed some cleavage. The CC Basics 3 Base tops span the fabric between the breasts allowing the outfit to show some cleavage. See the Preview Images for a visual comparison.
Includes:
1x CC 1.5 Cloth Cleavage Bustier Base (with Leather material as default)
1x CC 1.5 Cloth Cleavage Corset Base (with Leather material as default)
1x CC 1.5 Cloth Knee Length Skirt (with Leaher material as default)
1x CC 2.0 Cloth PBR Cleavage Bustier Base (with Latex material as default)
1x CC 2.0 Cloth PBR Cleavage Corset Base (with Latex material as default)
1x CC 2.0 Cloth PBR Knee Length Skirt (with Latex material as default)
Bonus: 1x CC 1.5 Cloth Cleavage Bustier V2 Base (version 2 of the Cleavage Bustier is been remapped to provide a more uniform texture mapping supporting things like logos).
These bases are intended as budget alternatives to the more detailed (but also more expensive) bases sold in the content store (like the essentials pack or the professional outfit pack) or some of the bases offered by professional content providers in the marketplace. These bases may not be as detailed but they are being offered at a considerably lower price.
Attention: If you are using this with CC 1.5 you will not be able to use the three CC 2.0 PBR versions of the bases. If you are using CC 2.0 you should be able to use both the Traditional Shader CC 1.5 versions and the C 2.0 PBR versions.
CC1 CharacterCC Component
PBRExtended
