  • Material > Material (20)
  • Set > Props (3)
Bigboss is proud to announce the arrival of a series of absolutely outstanding and stunning fully animated PBR Morphable Creatures by SFBStudio.
This is the PBR BatsPack by SFBStudio.
This Pack contains 3 PBR Morphable Bat Creatures for iClone plus 20 high-quality Materials you can use to customize different parts of your character. The Creatures are supplied as Morphable Props with 21 Embedded Animations.
About SFBStudio Creatures:
Each Creature uses high quality PBR texture maps and a very small polygon count providing excellent visual quality for close-up shots.
Method of use:
1) Simply Apply the Prop to your scene
2) Right Click on the Creature to select the appropriate performance
3) Use the iClone "Multi-Duplicate" tool to clone each Creature
4) Use the Morph Animator to further customize your creature
5) Edit the applied animations on the timeline to add randomness to each character move.
6) Another interesting trick is to attach all your Creatures to a dummy Prop and have the prop follow an iPath during the animation !
Have fun!
UniversalUniversal
PBR
