Project > Project (1)
Set > Terrain (1)
Stage > 3D Scene (1)
Set > Props (4)
This is the ''Deep Ocean'' High-Resolution 3D Scene by Bigboss.
iClone 3DScenes are a fast and efficient way to save and restore complete movie Sets in iClone projects including Terrain, Water, Trees, Grass and Atmosphere.
This pack contains a complete ready made Deep Ocean 3DScenes with DEMO project including a Deep Ocean Terrain, an animated Deep Ocean Wave Prop with large waves plus sea accessory props (Rocky Boat, flock of Animated Seagulls and Moon). You can further customize the scene by adding additional boats, Characters and other Props to perfectly suit you specific needs. The Ocean Prop Features Large Animated Waves just like those you would find in the Deep Sea.
Each 3DScene by Bigboss use a very low polygon count and are further optimized for real-time performance by mirroring the very large backdrop and sky images (left-right) and by making judicious usage of tiles so that PBR Shaders can be used efficiently across the entire ground section to provide a very crisp rendering across the entire terrain. Furthermore, the ground is split into 3 separate tiled sections (ground, wall and wall top) so that different PBR materials can be applied to separate the ground from the backdrop when appropriate.
The high-resolution images used in the backdrop are royalty free images derived from web resources, 3D.SK and Pexels.com and further modified to provide the exact feel for the backdrop thematic.
Method of use:
1) Load the Project
2) Press Play!
3) Add your Boats, Characters and other required Deep sea Props to further customize your scene.
4) Further customize by attaching your characters to the appropriate Rocky Boat bones (depending where the character stands).
Bigboss 3D Scenes provide a crisp and clear Environmental Set for all your movie requirements. They are a perfect complement to the amazing series of World Builder Packs distributed by Bigboss by serving as the main Terrain and Backdrop to position your World Builder Props.
Notes:
For optimal performance, ensure your Max Real-time Map Size is set to 8192 x 8192 or more in your iClone's preference panel.
These 3DScenes shine by their beauty.
Have fun!
Bigboss40@videotron.ca
iClone > Project > Theme > Functional Demo Project
iClone > Set > Terrain > Nature Terrain
iClone > Stage > 3D Scene > 3D Exterior Scene
