For iClone only:
  • Set > Terrain (4)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Very High Resolution Seasonal Terrains Packs with 8K PBR Shaders called 8K PBR Terrains.
This is the Canyon River 8K PBR Terrain Pack.
The pack contains a total of 4 Seasonal Terrains delivered to you in iClone Terrain format featuring 4 sets of very high resolution (8K x 8K) seasonal PBR Shader Maps for use in Spring, Summer, Automnal and Winter scenes.
Method of use:
1) Apply Terrain to scene;
2) Complement by adding Sky, Water, Grass, Trees, Bushes and your favorite props;
3) Optionally copy colormap terrain texture into IBL (Image Based Lighting) channel, activate IBL and adjust IBL strength to your liking.
INPORTANT TECHNICAL NOTE
For maximum user experience, make sure your "Max Texture Size" parameter is set to 8192x8192 in the iClone Preferences panel.
[/b][b]2) Optionally reduce the amount of Graphics Ram required by removing or reducing the size of the Ambient Occlusion, Metallic and Roughness texture maps
About Bigboss 8K PBR Terrains:
Each terrain feature perfectly flat UV Maps (no distortion) with applied PBR materials generated from highly detailed multi-layered substances made in substance designer and baked into 8K x 8K shadermaps representing every season (Spring, Summer, Autumn and Winter) resulting in stunning level of details for all your seasonal scene requirements!
These terrains shine by their beauty.
8K PBR Terrains are complementary to all other Bigboss Environmental Packs.
Have fun!
Bigboss40@videotron.ca
UniversalIC-Non-Exportable
