  • Character > Accessory (1)
  • Character > Avatar (1)
  • Character > Cloth (2)
Bigboss is pleased to introduce Anatomically accurate Photorealistic Male Base for the Reallusion iClone Character Creator 3.3 Tool.
This pack includes 1 Digital Human Skin CC3+ Nude Male character with style_40 Male Genitalia.
NOTE: This character use Reallusion CC3+ Digital Human Shader for Skin, Eyes, Teeth, Hair and Genitalia along with SSS (Sub-surface Scattering) and Micro Normal technology.
SPECIAL FEATURES:
- The Genitalia part uses a high resolution mesh fully skinned to the Character bone structure and thereby will look perfect in any character position;
- The Digital Human Skin shader also applied to the Genitalia part.
- The Digital Hair shader also applied to pubic hair
- Morph sliders are available in CC to adjust pubic hair length.
- The Genitalia part and pubic hair can be applied to other CC3+ Male characters. (see technical note below)
With the exception of the Pubic hair morphs which are available to adjust the length of the pubic hair, the Genitalia parts on this character do not contain any morphs as these are forbidden by Reallusion EULA.
ADDITIONAL TECHNICAL NOTES:
1) The Genitalia will automatically fit any morph deformations applied to the base Character in Character Creator (e.g. Heavy, Strong, Athletic, Curvy, Thin, Old, etc.) thereby providing you with endless female character size and shape possibilities.
2) When applying the Genitalia part to other CC3+ characters, you also need to carry over the Opacity texture file that is on the Std_Skin_Body material provided with the base character in this pack.
3) When making Digital Skin adjustment changes to the Std_Skin_Body Material, you also need to make the exact same adjustments in the corresponding Materials of the MeshGenitals Cloth Materials.
Method of use:
1) Edit in Character Creator
2) Shape and customize Character to your liking
3) Save as new Character in Character Creator
4) Export Character to iClone
5) Save in iClone
6) Optionall apply Genitalia part or pubic hair on other CC3+ characters. (see technical note above)
Have fun!
Bigboss
Bigboss40@videotron.ca
CC3 CharacterCC3+ CharacterUniversalCC Component
PBRMatureExtended
