  • Set > Props (50)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning City Streets Modular Construction Kits for iClone.
This is the ''City Streets Modular Construction Kit'' by Bigboss.
This pack include a total of 42 Modular City Street Segment Props plus 8 commonly found City Street artefacts. The Street segments can be assembled in just about any type of City street network including T and X Crossings and rounded curves.
Each segment can be easily assembled together with a default Grid snap setting of ''100cm'' and an angle setting of 10 degree thus providing with complete seamless connectivity.
Best Used in any scene requiring good quality close-up Roads or Streets
Method of Use:
1) Make sure the ''Snap To Grid'' options are set in the iClone preference panel (100 cm, 10 Degrees)
2) Start by loading the Ground Base (to attach all other pieces)
3) Load and connect desired street segments
4) Multi-Duplicate segments that are used several times to optimize texture map resource usage
5) Apply Street Artefacts.
6) Parent all Street segments and Artefacts to the Ground Base
7) Select the Ground Base and Auto-Link All Material Textures from the modify materials panel to save on resources
About Bigboss City Streets Props:
Bigboss City Streets Props use a very small polygon footprint and high resolution PBR shader Maps. You can also apply and Bake other PBR Substances to each Tile or Prop Material to further customize your assets providing you with a high value pack with endless capabilities.
A Must have for all serious City Lovers !
Have Fun ! :)
Bigboss40@videotron.ca
Universal
PBR
