  • Set > Props (16)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning City Streets Modular Construction Kits for iClone.
This is the ''City Streets Subburban Houses Vol.1'' by Bigboss.
This pack include a total of 15 Fully Textured Subburban House Props plus a Ground Base. The Building Props are optimized to provide highly detailed facades featuring separate materials for individual structure parts such as floor, door frames, doors, indents, wall mounted lights, stairs, miniroofs, ledges, sidings, fixtures, covers, roof antennas, roof buildings, roof sides, roof, numerous windows and window types, window blinds, window shutters, miscellaneous metal parts, interior walls, roof drain, wall pillars, porches, staircases, balconies and more. You can also further customize each building by applying new materials or by baking substances materials to individual structure parts.
Best Used in any scene requiring good quality close-up of Houses
Method of Use:
1) Start by loading the Ground Base (to attach all buildings)
2) Apply the desired house to your scene
3) Multi-Duplicate houses that are used several times to optimize texture map resource usage
4) Parent all houses to the Ground Base
5) Select the Ground Base and Auto-Link All Material Textures from the modify materials panel to save on resources
6) Optionally add and position individual point lights INSIDE houses to create great lighting effect for night scenes
About Bigboss City Streets Props:
Bigboss City Streets Props use a very small polygon footprint and high resolution PBR shader Maps. You can also apply and Bake other PBR Substances to each Tile or Prop Material to further customize your assets providing you with a high value pack with endless capabilities.
A Must have for all serious City Lovers !
Note: This pack is fully compatible and complementary to Bigboss's City Streets Modular Construction Kit.
Have Fun ! :)
Bigboss40@videotron.ca
Universal
PBR
