Set > Terrain (1)
Stage > 3D Scene (1)
This is the ''Desertic Oasys'' High-Resolution 3D Scene by Bigboss.
iClone 3DScenes are a fast and efficient way to save and restore complete movie Sets in iClone projects including Terrain, Water, Trees, Grass and Atmosphere.
This pack contains a complete ready made scene you can load into your existing project and further customize by adding or repositioning Trees, Grass and other Props to perfectly suit the specific needs of your scene. The Terrain features High Resolution PBR shaders providing you with very crisp ground close ups. Furthermore, you can also move, scale and rotate the entire scene to perfectly suit your requirements by selecting the Terrain object via the Scene Manager panel and by applying the desired transformation in the Terrain Modify Panel.
Each 3DScene by Bigboss use a very low polygon count and are further optimized for real-time performance by mirroring the very large backdrop and sky images (left-right) and by making judicious usage of tiles so that PBR Shaders can be used efficiently across the entire ground section to provide a very crisp rendering across the entire terrain. Furthermore, the ground is split into 3 separate tiled sections (ground, wall and wall top) so that different PBR materials can be applied to separate the ground from the backdrop when appropriate.
The high-resolution images used in the backdrop are royalty free images derived from web resources, 3D.SK and Pexels.com and further modified to provide the exact feel for the backdrop thematic.
Method of use:
1) Load the 3DScene into your project
2) Position the camera to your liking
3) Add your Buildings, Vehicles, Characters and other required Props in your scene.
4) Further customize by adding more Trees or any type of Water, Grass and Moss.
5) Press play !
Bigboss 3D Scenes provide a crisp and clear Environmental Set for all your movie requirements. They are a perfect complement to the amazing series of World Builder Packs distributed by Bigboss by serving as the main Terrain and Backdrop to position your World Builder Props.
Notes:
For optimal performance, ensure your Max Real-time Map Size is set to 8192 x 8192 or more in your iClone's preference panel.
These 3DScenes shine by their beauty.
Have fun!
Bigboss40@videotron.ca
iClone > Set > Props > Nature Prop
iClone > Set > Terrain > Nature Terrain
iClone > Stage > 3D Scene > 3D Nature Scene
