  • Set > Props (73)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animated Mechanical Drive Assembly Props for iClone called ''EZ Gears''.
This is the EZ Gears Mechanical Drive Construction Kit by Bigboss.
This pack includes 73 fully animated Gear Assemblies including Belts, Pistons, Bicycle Chains, Multiple Gear Trains and Pulleys. The Props are low polygon count and are fully optimized for real-time response.
Best use in Steam Punk, Mad Max, Sci-Fi or Futuristic style Movies or any Movies requiring Robotics or Mechanical Assemblies.
Method of Use:
1) Apply EZ Gear Props to your scene
2) Build desired Mechanical Drive assemblies
3) Attach your rotating props to the desired Gear
4) Adjust Rotating Speed by stretching or compressing the animation Clip on the Timeline
5) Press Play
6) Multi-Duplicate as desired
7) Optionally attach all components to dummy Prop and use the "auto-link all object textures" option to optimize material resource usage
8) Save Assembly for future use by saving dummy prop.
Further customize by modifying the Materials for Gear, Piston, Rod, Belt and Shaft.
This Pack is complementary to all other EZ Gear Packs by Bigbos.
Have Fun ! :)
Bigboss40@videotron.ca
Universal
PBR
