For iClone only:
  • Set > Music (4)
  • Set > Props (5)
For Character Creator and Cartoon Animator and iClone and Popvideo :
  • Popvideo_share > Popvideo (6)
Bigboss is extremely proud to announce the arrival of a series of amazing Animated Props with Audio & popVideo Special Effects for iClone called EZ SFX.
This is the EZ SFX Explosive Props Vol.1 by Bigboss.
This Pack contains 5 fully animated explosive props (Gunpower Barrel. Bomb, Grenade, TNT Crate with Dynamite sticks and animated Countdown Timer). The props include the explosion animations plus corresponding Audio/Video special effects..
A must have for all Action Movie Lovers require explosions !!!
Method of use:
1) Apply Prop to scene
2) Press Play
3) Futher customize by moving clips on the timeline
About Bigboss Special Effects:
Each prop uses low polygon structure with high resolution PBR shader maps. The explosive animations are baked from projects using high end physics engine with special audo video effects. The props and special effects are modular thereby can be used separate of as a whole joinltly with other props..
Have fun!
Bigboss40@videotron.ca
UniversalUniversalUniversal
PBR
