Actor > Non-Standard Human (1)
Set > Props (11)
This is the Befouler Character Pack by MaxBugor
This Pack contains 1 Befouler Character for iClone plus 11 accessory Props including a Spring loaded Befouler Arm & Legs Prop. The character is provided as non-standard human character for iClone compatible with iClone standard human motions.
About MaxBugor Characters:
Each Character uses high quality PBR shader maps and a very small polygon count providing excellent visual quality for close-up shots. Some characters have soft cloths for the kilt armor part.
Important Technical Note: Some characters have optional parts (e.g. different heads, helmets, body part,...) that can be reveiled or hidden by moving their respective opacity sliders from within the Modify/ Material Editor panel.
Method of use:
1) Simply Apply the Character to your scene
2) Drag & Drop any iClone standard human motions on the Character
3) Press Play
iClone > Actor > Humanoid > Sci-Fi Humanoid
