Actor > Accessories (4)
Actor > Legacy Standard Human (1)
Material > Lower Body (1)
Material > Shoes (1)
Material > Upper Body (1)
NOTE: ADDED THE DRESSED CHARACTER TO THE PACK ON APRIL 12, 2016.
Everything you need to create a Biker Character for "Chubby" from Reallusion ToonMaker2 Pack.
1) Add Chubby to the stage
2) Add the "SUIT" upper
3) Add the "FLAT HEEL" shoes
4) Add the "WORKER" lower
4) Select Upper Tab at top and in Modify Panel on right, "Load Material" and navigate to your material files to find Chubby Biker UPPER.
5) Select Lower Tab and in Modify Panel on right, "Load Material" and navigate to your material file for Chubby BIKER Lower.
6) Select "Shoes" Tab and then Load Material and navigate to the Biker Flat Heel Shoes.
7) Add the Accessories for HeadScarf, Bracelet, Earring and Cigar (in folder in your content Manager under Accessories labelled ToonMaker2/Chubby/Biker.
8) Add desired eyes, nose, ears, etc. from Accessories in ToonMaker2 pack (or you can also use ToonMaker 1 or Monster Pack Accessories if you desire).
ToonMaker by Reallusion is available HERE
Other ToonMaker 2 Characters you might like:
