  • Fix bug and update to iClone 8.3
  • Contain main_ic7.py for iClone 7 user
Bug report: w94028@gmail.com
(2023/4/10)
  • Due to the change of API, this plug-in might not working.
  • I currently start fixing the problem and will update this plug-in for iClone 8
Blend Camera plugin can help you quickly set up camera switching, and easily configure the transition tweening, without modifying your current settings.
Install( iClone 8 ):
1. Unzip the downloaded file.
2. Move BlendCamera folder into the iClone install directory > ...\Bin64\OpenPlugin.
Install( iClone 7 ):
3. Delete main.py
3. Rename main_ic7.py to main.py
Notice:
Blend Camera does not record Near Clip Plane, Far Clip Plane, Fit Render Region, Fit FOV, and Camera Aperture (no API support).  You'll need to adjust these settings before recording.
Blend Camera does not store the current session after restarting the project.  You will need to close the window and start a new session.
DOF data can be recorded, but will significantly increase the setup time.
UniversalIC-Non-Exportable
