For iClone only:
  • Project > Project (1)
  • Set > Props (26)
Build a Terrain
Introducing a cool new way to make your own terrains. Are you tired of just getting one version of a terrain to use? Well what if you could create your own terrain any way you wanted, with several variations of curves and straights, a bridge overpass, streams, waterfall, mountains, crossroad and more? Now you can with the all new “Build a Terrain Pack”. All the sections are props so they can be laid out in any fashion you wish. Once you have your terrain the way you want, simply select all the props and convert them to terrains.
Now your vehicle will follow the lumps, bumps and slopes of the mountain terrain you just built. I have included not only flat terrain sections but also elevated sections so your vehicles can climb the mountain and cruise around over streams and other road sections with the use of the overpass and bridges that are included. Never have you had so much fun laying out road as you will have with this set. I have included a complete terrain already laid out for you to start driving on to get you started, but of course you will want to come up with your own designs too.
Here's what you get:
6 Straights including 2 flat, 1 sloped, 1 rolling, 1 elevated, 1 stream crossing
3 Curves including 1 flat, 1 sloped and 1 elevated
1 T shaped road
1 Crossroad
1 Overpass
4 Stream sections including 1 straight, 1 straight with a culvert end, 1 curved, 1 curved with a culvert end
1 Waterfall
2 Bridges
1 Stream
1 Culvert pipe
3 Backdrops including 2 straight mountain sections and 1 corner mountain section
2 Flat land sections to be used as a filler between road sections
1 Complete terrain already set up with 2 paths to travel on
A total of 26 sections for an endless number of terrains that can be made.
More cool stuff coming soon!
Readme file: How to Use.pdf
UniversalUniversal Project
