For iClone only:
  • Actor > Non-Human/Creature (1)
  • Animation > iMotion (20)
  • Set > Props (1)
Bigboss is proud to announce the arrival of a series of absolutely outstanding and stunning fully animated Animals & Creatures.
This is the Bulldog Puppy Animal by Bigboss.
This Pack contains a Bulldog Puppy Animal for iClone plus 20 high-quality Puppy Dog Motions. The Animal is supplied both as a Non-Human Avatar and as an iClone Prop with embedded animations.
About Bigboss Animals & Creatures:
Each Character use high quality texture maps and a very small polygon count providing excellent visual quality for close-up shots. The Prop version of the Character provides additional functionalities such as the capability to use the multi-duplicate iClone feature and the capability to apply key frames to the scaling of bones which may be required by some of the provided custom animations.
Method of use:
1) Simply Apply the Character Avatar or Prop to your scene
2) Right Click on the Character to select the appropriate performance
3) You can alternatively Drag&Drop motions on the Avatar version of the Character
4) Use the iClone "Multi-Duplicate" tool to clone the Prop version of each Character along a vector or circular path.
5) Edit the applied animations on the timeline to add randomness to each character move.
6) Another interesting trick is to attach all your Character to a dummy Prop and have the prop follow an iPath during the animation !
Note: Some motions provided in this Pack originate from Sen's original Dog Character base Motions.
Have fun!
Non-humanUniversalUniversal
