Product Name: C247A Trey Overcoat 02 Upper Template Map Required Base: Trey_Overcoat 02 & Baggy A or Trey_Overcoat 02 & Baggy B From: <a href="http://www.reallusion.com/contentstore/csproduct.aspx?contentid=AIC320DIENU010620090526001&MenuItem=ic_avatar&Type=G3%20Character" target="_blank">G3 CloneCloth for Essential Man Vol.1 </a> Note: For this material to work on your iClone, you must first purchase the required base listed above How to apply: 1. Load the base model first 2. Load the material from Modify Menu (The Material can be found under the Materials Lib folder in your iClone3 Template)
Required base Contents
Universal
