Product Name: C285A Violet Petticoat Upper Template Map Required Base: C285A_Violet_Petticoat A or C285A_Violet_Petticoat B From: <a href="http://www.reallusion.com/contentstore/csproduct.aspx?contentid=AIC320DIENU010620090630001&MenuItem=ic_avatar&Type=G3%20Character" target="_blank">G3 CloneCloth for Essential Woman Vol.1 </a> Note: For this material to work on your iClone, you must first purchase the required base listed above How to apply: 1. Load the base model first 2. Load the material from Modify Menu (The Material can be found under the Materials Lib folder in your iClone3 Template)
Required base Contents
Universal
