Product Name: C285A Violet Slim Upper Template Map
Required Base: C285A_Violet_Slim & Sheath A or C285A_Violet_Slim & Sheath B
From: <a href="http://www.reallusion.com/contentstore/csproduct.aspx?contentid=AIC320DIENU010620090630001&MenuItem=ic_avatar&Type=G3%20Character" target="_blank">G3 CloneCloth for Essential Woman Vol.1
</a>
Note: For this material to work on your iClone, you must first purchase the required base listed above
How to apply:
1. Load the base model first
2. Load the material from Modify Menu (The Material can be found under the Materials Lib folder in your iClone3 Template)
Required base Contents
