Set > Props (2)
This is the Cartoon Animal Saber Tooth by 4ToonStudio
This Pack contains 1 fully animated Cartoon Animal Saber Tooth for iClone including 27 high-quality Embedded Animations. The Creature is supplied in 2 different textures as an iClone iProp with embedded animations.
About 4ToonStudio Animals & Creatures:
Each Character use high quality texture maps and a very small polygon count providing excellent visual quality for close-up shots. As animated Props, each Character provide additional functionalities such as the capability to use the multi-duplicate iClone feature and the capability to apply key frames to the scaling of bones which may be required by some of the provided custom animations.
Method of use:
1) Simply Apply the character to your scene
2) Right Click on the character to select the appropriate performance
3) Edit the applied animations on the timeline to add randomness to each character move.
4) Use the iClone "Multi-Duplicate" tool to clone the Prop along a vector or circular path.
5) Another interesting trick is to attach or link your animated character to a dummy Prop and have the prop follow an iPath during the animation!
Have fun!
iClone > Set > Props > Wild Animal Prop
