Set > Props (1)
Cartoon Room by Dexsoft Games
Cute cartoon room is an ideal setting for your favorite toon characters. The room is supplied fully furnished, and each item is a sub-prop which can be saved to re-use or moved around if you so desire. Additionally, there are two doorways with the default iClone door attached (you can easily remove them) which have built in animation for "Open Door" or "Close Door" or for your avatar to interact using the "Operate" commands.
Last 4 promos are rendered in iClone and the last one has some iClone characters added to show the dimensions, etc.
The room can be re-sized larger or smaller to suit your characters base size for ideal interaction with the props.
