For iClone only:
  • Actor > Legacy Standard Human (24)
Casting "Extras" - "Biblical" - Lo Poly Formal Characters - by Apparition & Alley
Casting "Extras" is a new product by Apparition/Alley. The Citizen Extra product by Reallusion was a great product in it's time, but is outdated and only provides for very basic modern day clothing, with no option of facial animation. These characters work with all iClone standard motions, along with the facial animation and puppetry. They can each speak and be animated independently. And, Apparition has been able to reduce the poly count of each character to under 10,000 polys for the males and under 9,000 for the females. Hair has been reduced as well - some hairs on males & females will bring the count slightly higher.
This is the fourth Grouping in the series called "Biblical". These Low poly characters include 24 avatars, as you see in the pictures. Pack includes 10 female, 11 Male and 3 Variations of Roman Soldiers. Multiple variations in faces and body size are included. For variety, simply apply the Facial "Morph" selections, use the "Detail" selection and adust facial features or manually select the various sliders to change the look. Also, use the randomizer. Please note that if you should use the face mapping customizer, the head will be transformed into a G5 head and the polycount will go up by about 4,000. The heads were generated in iClone 4, which keeps the poly count down. Therefore, I would strongly suggest you do not use the customizer, if you plan to use a high number of these avatars and you want to keep the scene simple. All G3 heads from iClone 4 can also be used, without increasing the poly count.
The males and female characters are 8500 - 9000 polys each including hair and accessories and the Roman Soldiers including shields, speers and helmets are around 12,000. With no accessories, Romans are around 9,000. All headpieces are accessories that can be removed. Hairs included and are reduced poly hair and included in the poly counts.
Many of you have requested this type of lo-poly character to fulfill a need for filling your scenes with multiple characters, and we sincerely hope that you will find these low poly characters useful.
Watch for more low poly characters in various genres very soon.
