Material > Upper Body (5)
5 Shirts based on the Casual Cloth PRCC by Vit 3D. The material files can be applied to either the Long Sleeve Shirt or the Rolled Sleeve Shirt. I've altered the buttons and RGB map from the original to suit striped shirt sleeves and allow for smaller buttons. Slight alterations also to the A/O and Normal Map as well.
To Use:
1) Dress character in CC with either shirt;
2) Adjust character dimensions if desired to customize
2) Export to iClone
4) Select Material at Top of Modify Panel at Right and Navigate to the Material File in your Template Directory.
Files will be installed:
Default Template Directory/Template/iClone_6_Template/iClone_Template/Materials_Lib/Upper/CC_Alley/PRCC_Casual_Cloth/Casual_Shirt_Vol._1
Note: Materials are also accessible by highlighting the Shirt in your Scene Manager, Select "Media" tab top left and on the list under Materials find the Folder Upper/CC_Alley/PRCC_Casual_Cloth/Casual_Shirt_Vol._1.
PRCC Casual Cloth - Click on Thumbnail Below.
Required base Contents
