For iClone only:
Actor > Legacy Standard Human (1)
Material > Material (4)
CC2 PBR Android iAvatar with glossy plastic shell, smooth metalic joints, and corrugated hosing between joints. The
CONTAINS:
1x CC2 PBR Android Standard Character iAvatar with 17 hard shell component iProps and 1 hoses CCCloth.
MATERIAL USAGE:
In order to reduce the download size of the iAvatar the white glossy shell material and the smooth metallic joints material is provided separately in the download. However, it is very easy to apply to the Android iAvatar using the following steps:
1. Add the Andriod iAvatar to a project
2. Select the Android iAvatar in the scene (ensure that you select the top level iAvatar not one of its sub components)
3. Select the Materials tab
4. Select any "Body" component
5. Ensure that "Apply to all materials with the same name" is checked.
6. Load the "Plastic Glossy White" material.
7. Select any "Hardware" component
8. Ensure that "Apply to all materials with the same name" is checked.
9. Load the "Metallic Smooth" material.
10. If you want the chest logo and back serial number:
a) Delected the ""Apply to all materials with the same name"
b) Select the "Torso_R" mesh
c) Load the "Plastic Gloassy White With Logo" material.
ANDROID VS CYBORG:
While this Avatar is intended to be used as an Android, the hard shell is implemented as props which can be attached and/or removed. The regular character texture is hidden (using opacity) which limits the visible components to the hard shell props and the hoses "cloth". This mens with some strategic opacity maps and removal of some of the hard shell props this character can be converted to a cyborg (as shown in one of the preview images).
CONTAINS:
MATERIAL USAGE:
ANDROID VS CYBORG:
