  • Character > Accessory (6)
Always carry a little extra protection with this CC Army Knife Set containg a CC PBR Army Knife accessory and a CC PBR Army Knife Sheath accessory. The sheath comes with two morphs allowing the animation of the opening and closing of the sheath's security strap.
The Army Knife Sheath comes with 2 morphs which can be applied using the Morph Animator. By default the Sheath comes with the security strap half opened. One morph can be used to close the security strap while the other can be used to completely open the security strap. To animate the opening of the security strap, start with the Closed morph applied. Gradually remove this morph. Once the Closed morph is fully removed, gradually apply the Opened morph.
For user convenience three contents are provided: the CC PBR Army Knife attached to the right hand, the CC PBR Army Knife in its sheath attached to the belt area, the CC PBR Army Knife in its sheath attached by straps to the left forearm (giving the right hand quick access to the knife). It should be noted that while these three positions have been provided, the user can easily use the CC or iClone interface to reposition the contents to any location. By resizing the straps, the sheath can be, for example, easily attached to the upper leg or lower leg. Similarly the contents have been prepared for a rigth handed character but the user is free to move the contents to the other side for a left handed character.
The CC PBR Army Knife Sheath has not been provided as an independent content item but when either of the knives in their sheath are added, the sheath and knife are appear as individual entries in CC and thus the knife can easily be deleted in in order to get only the sheath. The resulting sheath can then be re-saved for future convenience.
CONTAINS:
1x CC2 PBR Army Knife Accessory.
1x CC2 PBR Army Knife in Sheath attached to the belt area (belt not included) with dual morph animation.
1x CC2 PBR Army Knife in Sheath attached to the left lower arm with straps with dual morph animation.
*Bonus: Each of the above items is also provide in a second Reduced Poly Count version.
Universal
PBR
