CC2 Knee Lenght (or Shorter) Skirt Morph Cloth Base is the 2nd item in the Lord Ashes' Warehouse Morph Cloth line.
This particular Morph Cloth item provides a knee length skirt with a length morph, a flare morph, a taper (pencil skirt) morph and a fit adjustment morph for making all kinds of knee length (or shorter) skirts. The preview video shows some sample possibilities but much more styles can be created by combining various amounts of the provided morphs.
Includes:
1x CC2 Morph Cloth Knee Length Skirt Base (with sample office grey cotton texture)
[/b]
[b]Morphing Notes:
1. The base comes with a weight map for use with the Physics engine. However when using either the flare morph or the taper (pencil skirt) morph the weight maps (if Physics are used) will need to be adjusted or removed otherwise gravity will just undo the flare or taper.
2. The morphs are currently only available in iC7 (not CC2). A character can still be dress in the skirt in CC2 but morph adjustments need to be made using Morph Animator in iC7.
3. After the desired morphs have been applied in iC7, the results can be pushed back to CC2 (i.e. Edit in Character Creator) and saved as CC Cloth with the morphs applied.
4. By combining different amounts of the morphs many different styles can be generated.
These bases are intended as budget alternatives to the more detailed (but also more expensive) bases sold in the content store (like the essentials pack or the professional outfit pack) or some of the bases offered by professional content providers in the marketplace. These bases may not be as detailed but they are being offered at a considerably lower price.
CC1 CharacterCC Component
Extended
