For iClone only:
  • Actor > CC Standard Human (5)
This is a stand alone CC2 Large Facial Scars Set which includes 5 facial scars (Eye scar, cheek scar, nose scar, upper lip scar and full lip scar) without the need for the CC Essentials Pack.
Note: Each scar is provided on a CC2 Base Male (PBR) avatar but the content is intended to be saved (see preview images for instructions) and re-used on any CC2 character.
Contains:
1x CC2 (PBR) iAvatar with Eye Scar Blend and Eye Scar Bump map
1x CC2 (PBR) iAvatar with Cheek Scar Blend and Cheek Scar Bump map
1x CC2 (PBR) iAvatar with Nose Scar Blend and Nose Scar Bump map
1x CC2 (PBR) iAvatar with Upper Lip Scar Blend and Upper Lip Scar Bump map
1x CC2 (PBR) iAvatar with Full Lip Scar Blend and Full Lip Scar Bump map
Known Issues:
1. Applying the scar bump map, which gives the scar its dimensional look, removes the regular CC2 head bump map which is typically used to give the skin a bit of a porus texture. As a result the skin may appear a bit smoother when the scar is applied unless the user combines the cc2 head bump map with the provided scar bump map.
2. Only one scar can be applied at one due to the single Blend channel provided by CC2/iC7. If multiple scars are desired, the scar Blend files and scar Bump files need to be merged manually in a image editor ahead of time.
Take Me To Lord Ashes' Warehouse For More Great Content...
CC1 Character
