Set > Props (5)
CC Light Shafts Prop - cone
CC Light Shafts Prop - faces camera
CC Light Shafts Prop - horizon
CC Light Shafts Prop - main wide
CC Light Shafts Prop - narrow shaft
The CC Light Shafts pack is just 40 points and consists of three adjustable props for overlaying light shafts onto your scenes - a normal spread, a narrow beam, and a horizon prop. These are very low-poly 2D opacity props, and will keep your scenes speedy while adding beautiful and subtle atmospheric effects.
There is also: an additional 2D Billboard which always faces the camera, and a 3D cone mapped with the effect (this can be useful for getting "the play of light effect" for underwater scenes).
This pack will be especially useful for those seeking to light larger scenes such as cathedrals, old abandoned warehouses, forests, etc - but will also be useful in more domestic scenes (e.g. a fantasy inn with light coming through the windows).
Props can be shrunk, enlarged, opacity-adjusted, re-colored, etc, for all sorts of additional uses!
