  • Character > Cloth (2)
Base Content
A Matte Black Leather Front Laced Corset with Metalic Grommets and Lacing based on Lord Ashes' CC Cleavage Corset base.
Includes:
1x CC 2.0x Cloth CC Cleavage Corset base with (PBR) Texture, Opacity, Bump, AO, Metalic and Rougness files (applied).
1x CC 1.5x Cloth CC Cleavage Corset base with (Traditional) Texture, Opacity, and Bump files (applied).
Attention:
If you are using this with CC 1.5x you will not be able to use the CC 2.0x PBR versions of the base. If you are using CC 2.0 you should be able to use both the Traditional Shader CC 1.5 versions and the CC 2.0x PBR versions. However, in this case the CC 2.0x version and the CC 1.5x version are almost identical in look. The most significant difference is that the grommets looks more metalic in the CC 2.0x version.
CC1 CharacterCC Component
PBRExtended
