For Character Creator only:
Character > Morph Data (9)
This is a CC Morph pack for creating amputations and/or severed limbs from CC characters. This Morph pack is not compatible with CC4 characters.
Includes:
1x Head Amputation CC Morphs
2x Hand Amputation CC Morphs(Right and Left)
2x Arm Amputation CC Morphs (Right and Left)
2x Leg Amputation CC Morphs (Right and Left)
2x Foot Amputation CC Morphs (Right and Left)
How To Use:
1. Create or load a regular CC character in CC.
2. Remove all clothing, hair, and accessories from the part of the character that is to be severed (i.e. the body part that is to be removed)
3. Reset all CC morphs on the part of the character that is to be severed. This is very important! The basic character does have morphs applied and these can cause artifacts if not reset.
4. Apply the desired CC Amputation morph (found in the "Amputation" sub-section of Actor | Body)
5. Export the character as an Avatar for use in iClone or elsewhere
Note: These are Binary morphs. You either set them to 0% or 100%. Values in between will produce odd effects not intended for use.
Known Issue:
There is a issue with using the foot or leg morphs on CC3 characters. The morph will get applied but it adjusts the floor footing and the characters crumples to the floor. This does not seem to occur with CC1 and CC2 characters. The issue is being discussed on the forum and a solution, if one is avaialble, will be posted once it has been arrived at. You can follow the conversation at: https://forum.reallusion.com/472066/Character-Creator-Morphs-And-Footing
Related Morphs:
This CC Morph Pack works well with the CC Morph Body Parts Set available here .
Includes:
How To Use:
Known Issue:
Related Morphs:
