This an CC2 Watch Morph Accessory Base. The morphs on the watch base allow you to create various watch shapes. Combined with different materials/textures an endless number of styles can be generated. The watch bases comes ith 6 morphs (square shape, rectangular shape, body height, base ramp angle, base ramp width, and knows sink). Illustration of each moprh effect in provided in the preview images.
The base uses a single texture map but each component of the watch has its own area of the texture map and thus each component can be texture individually. This also means that using opacity any component can be removed (e.g. remove the band for a pocket watch, remove the knobs, etc).
Contains:
1x iCC2 Watch Morph Accessory Base (with sample texture for a black plastic analog watch)
The other watches and monitors shown in the header are available as freebies (with this base).
Watches made with this base may appear odd (without some of the morphs applied) when in CC2 but they will appear and render correctly once taken into iC7.
Contains:
