CC2 Cape Morph Cloth Base (PBR) is an item in the Lord Ashes' Warehouse Morph Cloth line. This particular Morph Cloth item (okay...technically it is an morph accessory item but it is a clothing accessory) provides a cape which a length morph, a flare morph, a mantle morph. The cape features an inner lining so that the outside of the cape and the inside of the cape can have different textures (avoiding the ugliness of having a logo on the outside which appeas backwards on the inside).
This length morph allow the cape to be sized anywhere from a full length cape (down to top of shoes) to a mini-capelette which barely covers the shoulders.
This flare morph allow the cape flare to be controlled anywhere from a straight rectangle to a wide-flare triangle.
This mantle morph adjust the appearance of the cape around the front of the neck to the shoulders.
By varying the contrast of the provided weight maps, during physics soft cloth simulation, the cape can made to do anything from holds its shape rigidly, holds it shape with some folding and reaction to the physics all the way to fully fold and respond to physics.
All of these options are demonstrated in the sample silent video.
Includes:
1x CC2 PBR Morph Cloth Cape Base Accessory (with sample LA girl texture and logo)
Morphing Notes:
1. The morphs are currently only available in iC7 (not CC2). A character can still be dress in the skirt in CC2 but morph adjustments need to be made using Morph Animator in iC7.
2. After the desired morphs have been applied in iC7, the results can be pushed back to CC2 (i.e. Edit in Character Creator) and saved as CC Cloth with the morphs applied.
3. By combining different amounts of the morphs many different styles can be generated.
These bases are intended as budget alternatives to the more detailed (but also more expensive) bases sold in the content store (like the essentials pack or the professional outfit pack) or some of the bases offered by professional content providers in the marketplace. These bases may not be as detailed but they are being offered at a considerably lower price.
Universal
PBR
