This an CC2 PBR Medium Gauge Necklace Accessory with a CC2 PBR Morph Line Pendant Base Accessory.
The CC23 PBR Medium Gauge Necklace is a static CC (Head) Accessory consisting of multiple medium gauge links forming a fairly tight (i.e. for a high hanging pendant) necklace around the lower part of the neck. While the necklace can be somewhat animated via rotation to simulate the swing of the necklace, due to the fairly tight fit this kind of animation is typically not necessary.
The CC2 PBR Morph Line Pendant Accessory can be attached to the necklace and provides 6 morphs for changing the shape of the penant: Rounded Edge Slightly, Rounded Edge Fully, Round, Octagon, Triangle and Heart. When the morphs are applied, the texture about the morphed edges distorts a bit (i.e. suitable for material texture but not detailed texture) but the texture at the center of each morphed pendant remains constant and thus can be used for pendant details.
Morphs are applied in iClone using the Morph Animator. Note: In some cases, applied morphs may not be shown when the accessory is taken back to CC2. However, once the accessory is taken back to iClone, the applied morphs will (once again) be visible. This even inclues morphed accessories which are saved in CC2 and then added to a different chaarcter.
While the Pendant Base is provided with a sample red ruby gem so that it could be used as is, the Pendant is intended as a Morph Line Base from with many other pendants can be created.
Contains:
1x CC2 PBR Mediym Gauge Necklace iAccessory
1x CC2 PBR Morph Line Pendant iAccessory (with 6 morphs)
These bases are intended as budget alternatives to the more detailed (but also more expensive) bases sold in the content store (like the essentials pack or the professional outfit pack) or some of the bases offered by professional content providers in the marketplace. These bases may not be as detailed but they are being offered at a considerably lower price.
Take Me To Lord Ashes' Warehouse For More Great Content...
Universal
PBR
