Material > Material (3)
This is a CC3 PBR Arcane Sheer Fishnet Bodysuit that is infused with arcane symbols.
Notes:
The bodysuit is implemented as CC3 materials which add the bodysuit as a Blend Channel to a CC3 chaarcter's Body, Arms and Legs. After applying, you should be able to change the regular Diffuse, Opacity, Bump, AO, Metallic and Roughness channels to customize the chaarcter shin without removing the bodysuit.
Warning:
Since the bodysuit is implemented as a CC3 character material it canonly be used with CC3 characters (or any custom characters which have the same texture map layout for Body, Arms and Legs as CC3 chaarcters).
Usage:
I have not found a way to apply actual Materials in CC. As such you will need to push your CC3 character to iClone and then apply each of the 3 provided materials to the respective body part. There is one for Body, Arms and Legs. Once the material is applied the character can be pushed back to CC.
Notes:
Warning:
Usage:
