For iClone only:
  • Actor > Accessories (2)
  • Actor > CC iCloth (2)
  • Actor > Legacy Standard Human (1)
  • Actor > Shoes (1)
Base Content
Catholic Nun based on both Pope and Multi Smock by Delerna
NOTE: You must own the POPE GOWN by Delerna and Multi-Smock by Delerna in order to use these characters or you will get watermark.
Uses the Cape from the Pope and the straight gown from Multi-Smock. The neckpiece and the Habit are Accessories. Collisions have been pre-set on the avatar supplied. You can launch the characters in Character Creator and make changes to the shape and size of the character, but collisions will likely have to be adjusted to allow for the size changes.
Also supplied is the iCloth parts which will install in iClone so you can add to any other CC Character.
Install Locations -
Avatar in your Default iClone Directory - Avatar/CC_Alley/Nun
iCloth - Default iClone Directory - Body Parts/CC iCloth/CC_Alley/Nun
iShoe - Default iClone Directory - Body Parts/CC iShoe/CC_Alley/Nun
Habit & Neckpiece - Default iClone Directory - Accessories/CC_Alley/Nun
Pope Catholic Gown and Multi-Smock by Delerna - Click on Thumbs below.
CC1 CharacterLegacy ActorUniversal
