This python script will prompt you for 3 textures:
1. The blade texture
2. The 'Rod' texture (pole connecting to the ceiling
3. The base texture image
To use this, create your ceiling fans, then position them into place and click the menu option Animaiton - 'Remove Object Animation'.
Then launch the Python Script again and set the slider to the desired value and click 'Change Speeds'.
To stop the fans, run the script again, and set the Slider Speed to 0 (all the way to the left).
I was surprised there were not any ceiling fans in the marketplace.
Known Issue: Fixed
The issue of Frames per project being hard coded has been fixed.
UniversalIC-Non-Exportable
