Project > Project (1)
Set > Props (4)
Set > Props (56)
This is the Chalkboard with Particle Driven Alphabet by Cricky.
This package contains 3 Chalkboard Style Props (Chalkboard, Scoreboard, and Menu) plus a complete particle driven Chalk like Alphabet, Numbers 0-9, and a few symbols and punctuation items that can be drawn using the chalk tool and a Demo Project.
Choose the Letter, Number Symbol, etc., and then place it using the Grid provided as an image layer, or your own eyeball for placement needs. Each item has it's own dummy to show precise proximity where it will be when generated, so placement is easy.
Write out whole words or individual letters in sequence.
The option to do either is available, as each item has it's own perform functional command. Once placed, group with a dummy, and turn or rotate until satisfied. Scale to fit specific areas, but be advised that going too small will generate a "Blob" without distinguishable shape.
This is only a small sampling of what is possible.
Try doing Sky Writing as one additional example.
Think about building a Separate Library of Grouped words that can be used again and again; Time Savers over the long run which would only require that the animation be regenerated and the Particle aligned with that animation.
Timeline Speed for rendering can be reduced to approx 100 frames, or stretched to 1600. 200-300 will produce a fairly good production that takes approx. 3-4 seconds of generation time per letter.
Avatars can use Reach Targeting if you so desire on each letter to simulate an actual person writing on a board. Each Dummy letter has a Physical Mesh dummy that can be targeted by the Avatars hand.
Method of use:
1) Apply Chalkboard Prop to your scene
2) Choose the Letter, Number Symbol, etc., and then place it using the Grid provided as an image layer
3) Animate by invoking individual Perform commands
4) Press Play
Also see Geo Shapes Particle Drawn Pack : http://city.reallusion.com/ContentPreview.aspx?i=JICc28c5f6b991e85673&g=
These Props were created by Cricky.
Have fun!
iClone > Set > Props > Signs & Boards
