Combat Spec Ops - Female Sniper
20-Sniper-Idle
Designed specifically for UN Task Force - Female 1 and Female 2 Used with Sniper Rifles (SR-TAC300) and iClone 7
Only motions are included in this pack.
Characters and Weapons by Antareus can be found in the link below.
(UN Task Force Combo Pack by Antareus https://www.reallusion.com/ContentStore/iClone/pack/UN_TaskForce/default.html)
Gun alignment may be required
Also works with (Base_Female, Heidi, Gwynn, Jade), but needs slight gun alignment and positioning
Works with males and other humanoid characters, but will need a higher degree of gun alignment and positioning
Combat Motions - Designed specifically for UN Task Force Females
NOTES FOR ICLONE 6 USERS
I have made these motions available in 6.5, you will need to use compatible weapons and characters and higher alignment and positioning will be needed.
