Combat Spec Ops - Female Assault Rifles
26-Sniper-Kneel-Fire
Designed specifically for UN Task Force - Female 1 and Female 2 Used with Sniper Rifles (SR-TAC300) and iClone 7
Only motions are included in this pack.
Characters and Weapons by Antareus can be found in the link below.
UN Task Force Combo Pack by Antareus
Gun alignment may be required
Also works well with (Base_Female, Heidi, Gwynn, Jade)
Works with most other humanoid characters, but will need a higher degree of gun alignment.
Combat Motions - Designed specifically for UN Task Force Females
This motion does work in iClone 6.5 (Tested) but the UN Task Force weapons, gear and avatars are not compatible with 6.5 or lower
NOTES FOR ICLONE 6 USERS
I have made these motions available in 6.5, you will need to use compatible weapons and characters and higher alignment and positioning will be needed.
Standard Human
