Combat Spec Ops - Female RPG
44-RPG-Idle-to-Run
Designed specifically for UN Task Force - Female 1 and Female 2 Used with the RPG and iClone 7
Only motions are included in this pack.
Characters and Weapons by Antareus can be found in the link below.
UN Task Force Combo Pack by Antareus
Weapon alignment may be required
Also works with (Base_Female, Heidi, Gwynn, Jade), but needs slight weapon alignment and positioning
Works with males and other humanoid characters, but will need a higher degree of weapon alignment and positioning
Combat Motions - Designed specifically for UN Task Force Females
NOTES FOR ICLONE 6 USERS
I have made these motions available in 6.5, but you will need to find a replacement for the RPG and more alignement will be required.
Standard Human
