  • Set > Props (1)
Bigboss is extremely proud to announce the arrival of a series of amazing special iClone Animated Props by Cricky.
This is the Combination Safe and Dial by Cricky
This pack contains a Pre-Animated Safe. The Combination Dial has a built in Perform Command, the rest can be adjusted by use of the transform keys on the Time Line. All Rotations and Pivots are preset to make use easy. All areas are pre-textured, but allow change. Tiled Textures work best, but it is always the users choice. Each area has a UV Unwrap applied if you want to view the UV and change small areas specifically.
Take a look inside, there may be a hidden Item in there, if you can figure out the combination !
Method of use:
1) Apply Prop to your scene
2) Press Play...
This Prop was created by Cricky.
Have fun!
Universal
